rtems source builde git repository
Hoefle Marco Marco.Hoefle at nanotronic.ch
Wed Aug 27 09:17:52 UTC 2014
Hello Chris
same failure:
script: 74: cd "/home/NANOTRONIC/hoefle/projects/customers/unibern/cassis/clone/source_build_test/rtems-source-builder/rtems/build/sparc-rtems4.10-kernel-4.10-1"
script: 75: echo "=> sparc-rtems4.10-kernel-4.10-1:"
script: 76: echo "==> %prep:"
script: 77: source_dir_rtems="rtems-4.10"
source setup: sparc-rtems4.10-kernel-4.10-1: source rtems -q -c -n sparc-rtems4.10-kernel-4.10-1-4.10
making dir: /home/NANOTRONIC/hoefle/projects/customers/unibern/cassis/clone/source_build_test/rtems-source-builder/rtems/sources/git
_url: git://git.nanotronic:rtems.git?protocol=none?reset=hard?pull?branch=gr-4.10 -> /home/NANOTRONIC/hoefle/projects/customers/unibern/cassis/clone/source_build_test/rtems-source-builder/rtems/sources/git/git.nanotronic:rtems.git
git: clone: git://git.nanotronic:rtems.git -> sources/git/git.nanotronic:rtems.git
cmd: (None) /usr/bin/git clone git://git.nanotronic:rtems.git /home/NANOTRONIC/hoefle/projects/customers/unibern/cassis/clone/source_build_test/rtems-source-builder/rtems/sources/git/git.nanotronic:rtems.git
exe: ['/usr/bin/git', 'clone', 'git://git.nanotronic:rtems.git', '/home/NANOTRONIC/hoefle/projects/customers/unibern/cassis/clone/source_build_test/rtems-source-builder/rtems/sources/git/git.nanotronic:rtems.git']
fatal: unable to connect to :
: Name or service not known
Cloning into '/home/NANOTRONIC/hoefle/projects/customers/unibern/cassis/clone/source_build_test/rtems-source-builder/rtems/sources/git/git.nanotronic:rtems.git'...
error: git command failed (/usr/bin/git): 128hoefle at wheezy:~/projects/customers/unibern/cassis/clone/source_build_test/rtems-source-builder/rtems$
Regards,
Marco
-----Original Message-----
Sent: Wed 27/08/2014 10:46
To: Hoefle Marco; users at rtems.org
Subject: Re: rtems source builde git repository
On 27/08/2014 5:28 pm, Hoefle Marco wrote:
> _url: git://git.nanotronic:rtems.git?reset=hard?pull?branch=gr-4.10
Can you please try the attached patch with the URL of:
Thanks.
URL: <http://lists.rtems.org/pipermail/users/attachments/20140827/7aaa0f7e/attachment-0002.html>
