RTEMS available tasks
Tue Jan 28 14:34:44 UTC 2014
On 2014-01-28 15:30, Andre Marques wrote:
> Well, for me Qemu seems to be having some problems with the output, because I
> can set breakpoints, and run the code on the remote target, but Qemu doesn't
> show any output (with -nographic, and different consoles), or shows the output
> for the program passed with the -kernel parameter, regardless of what gdb says
> that is printing.
> For now I guess I'm leaving this as it is, as I've tried for several hours
> already to make the output work.
> On pc386 the -S option leads to a fatal error, because when loading the program
> it seems to load it on the Bios memory space. If I dont use that option all
> seems to work. As for arm, I could't get any output.
Which Qemu version do you use?  I normally use the latest Git version.
If you omit the -nographic option, then you need "-serial stdio".
The output appears on the terminal running Qemu (not the GDB terminal).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
