Application based on Pthreads is blocked under RTEMS
smc smc
smc101979 at gmail.com
Fri Jul 4 13:37:25 UTC 2014
Hi, thanks all for your suggestions.
@Sebastian: the bsp is MPPA.
@Gedare: I cannot send the full code for debugging, because part of it uses
an proprietary API :/ About your comment, I commit a mistake transcribing
the code, it is not an assignment operator, it must be '=='.
Anyway, I am trying to use condition variables, despite of loosing some of
performance.
Regards.
2014-07-03 2:37 GMT+01:00 Gedare Bloom <gedare at rtems.org>:
> I'll make one note below, but you should submit the entire
> self-contained example that shows the incorrect behavior if you want
> debugging help.
> On Wed, Jul 2, 2014 at 6:23 AM, smc smc <smc101979 at gmail.com> wrote:
> > Hi, I am new in RTEMS. I can't understand why the following threaded
> > application is not running on RTEMS as expected. Basically, it creates
> two
> > pthreads. One fills a buffer and the other one get an slice and submit
> it to
> > a cluster for processing (typical producer-consumer problem), something
> > like:
> > void thread1()
> > while(1)
> > for (i=0; i < size;i++)
> > if (buffer[i].st == -1)
> > pthread_mutex_lock(&mutex);
> > genData(buffer[i]);
> > buffer[i].st=0; // ready to be consumed
> > pthread_mutex_unlock(&mutex);
> > void thread2()
> > while(1)
> > // n stores the slice start
> > ready = false;
> > while (!ready) // it gets a free slice
> > ready = true;
> > for(i=n;i<n+slice;i++)
> > if (buffer[i].st = -1)
> If you have this statement with an assignment operator, the
> while(!ready) loop should never terminate if slice > 0.
> > ready = false;
> > // process the slice on cluster
> > for (i=n;i<n+slice;i++)
> > buffer[i].st = -1; // now new data can be inserted on it
> > It runs fine on a Linux/GNU system, but not in RTEMS. Under some
> > circumstances the program is blocked. It is like if thread2 was running
> > forever on the second while, and thread1 didn't fill the buffer. Do you
> have
> > any idea of what is happening? I would expect that each thread would run
> on
> > parallel on each core.
> > Thanks.
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20140704/8137cb54/attachment-0001.html>
