Creating a new BSP
Steven Grunza
steven.grunza at gmail.com
Mon Jun 30 19:23:55 UTC 2014
Can I create a new BSP by copying a very similar BSP (such as stm32f4) and
then adding the new directory to the acinclude.m4 file
in c/src/lib/libbsp/arm, then running bootstrap from the top level
directory?
As far as I can remember this is the procedure I used to create a BSP for
the STM32F3Discovery board; however, now that I need to use a
STM32F4Discovery (with really different pinouts than the current BSP) I'm
having trouble getting the system to configure. My configure output ends
with ...
checking whether gmake sets $(MAKE)... yes
checking whether gmake supports nested variables... yes
checking whether to enable maintainer-specific portions of Makefiles... yes
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
My STM32F3Discovery configuration output ends with ...
target architecture: arm.
available BSPs: stm32f3.
'gmake all' will build the following BSPs: stm32f3.
other BSPs can be built with 'gmake RTEMS_BSP="bsp1 bsp2 ..."'
My best guess is that I've forgotten to update a file but I haven't been
able to figure out which file. Any suggestions would be appreciated.
My development system is Fedora 20, I'm using recent "arm-rtems4.11-xxx"
tools from yum and my source code is from GIT HEAD (albeit a while ago).
My configuration commands are:
../rtems/configure --prefix=/home/rtems/rtems-411 --target=arm-rtems4.11
--enable-posix --enable-networking --enable-cxx --enable-maintainer-mode
--enable-rtemsbsp="stm32f3"
--enable-rtemsbsp="m4robot"
Steven G.
URL: <http://lists.rtems.org/pipermail/users/attachments/20140630/ce8b8686/attachment.html>
