RSB fails at building sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1
Mon Apr 20 05:02:30 UTC 2015
On 20/04/2015 2:31 pm, Hyungshin Kim wrote:
> I am installing RTEMS tools with RSB. While I was running the
> $ ../source-builder/sb-set-builder --prefix=$HOME/development/rtems/4.11 4.11/rtems-sparc
> as shown on the web, after 20 min, I got the build fail message as below.
> building: sparc-rtems4.11-gcc-4.9.2-newlib-2.2.0.20150323-x86_64-linux-gnu-1
> config: tools/rtems-gdb-7.9-1.cfg
> package: sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1
> building: sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1
> error: building sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1
> Build FAILED
>   See error report:
> rsb-report-sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1.txt
> Build Set: Time 0:14:24.333754
> Build FAILED
> In the rsb-report-sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1.txt file,
> it contains some info
> as follows.
> checking whether to use python... yes
> checking for python... /usr/bin/python
> checking for python2.7... no
> configure: error: python is missing or unusable
> make[1]: *** [configure-gdb] Error 1
> make[1]: Leaving directory
> `/home/eslab/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build'
> make: *** [all] Error 2
> shell cmd failed: /bin/sh -ex
>  /home/eslab/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/doit
> Can anyone help me what is going on ?
Can you please install the python27-dev or Python27 development
libraries on your host machine. The
  https://docs.rtems.org/rsb/
doco provides some options for a few hosts.
