Communicating with RTEMS instance running inside QEMU
Angelo Fraietta newsgroups at smartcontroller.com.au
Tue Aug 25 03:40:45 UTC 2015
I think you should be able to. There is a parameter in the call. How you
would do it, I don't know
rtems_task Init(
  rtems_task_argument argument
If you are using a file system, why not read the file after init starts -
maybe from a task and run your test from there?
On Tue, Aug 25, 2015 at 1:32 AM, Saeed Ehteshamifar <salpha.2004 at gmail.com>
wrote:
> Hi,
> What is the best way to communicate with RTEMS Init task? Is it possible
> to pass arguments to Init task when invoking QEMU?
> The problem is that I want to pass test case list to RTEMS, and the list
> might change during execution (if a test case execution fails, the test
> cases from the beginning up to after the failed test case should be removed
> from the list) so I can't hard code it in the compilation process.
> I was thinking to use a permanent filesystem (like jffs2) and control this
> process via a file which is edited by host and read by guest (RTEMS). Is
> there an easier/better way to do this?
> Kind Regards,
> SAeeD
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20150825/c80ebb3e/attachment-0002.html>
