Unable to build sparc toolset
Mon Dec 7 23:37:43 UTC 2015
On 12/08/15 02:32, Joel Sherrill wrote:
> On Mon, Dec 7, 2015 at 3:55 AM, Nick Withers <nick.withers at anu.edu.au
> <mailto:nick.withers at anu.edu.au>> wrote:
>     On Mon, 2015-12-07 at 13:53 +0530, Sambeet Panigrahi wrote:
>      > I have been into problems before because of my institute firewall, is
>      > it
>      > happening because of that? Can somebody please help me?
>     If you can't even view ftp://ftp.gnu.org then yes, I'd say it is.
>     Does this work for you? http://ftp.gnu.org/gnu/autoconf/
> Nick.. good idea. I wonder if we should ask Chris  to use http not ftp
> when it is available. Lots of firewalls block ftp.
Does https://devel.rtems.org/ticket/2482 help?
If http is supported and long term for a project then I do not mind. You
would need to edit each configuration file. GCI?
