Fwd: Unable to build sparc toolset
    Sambeet Panigrahi
    sambeet161616 at gmail.com
    Tue Dec  8 13:09:12 UTC 2015
>Hi Sambeet,
>If you can't even view ftp://ftp.gnu.org then yes, I'd say it is.
>Does this work for you? http://ftp.gnu.org/gnu/autoconf/
 Thank you Nick for the help.It works and I went on replacing several more
files required in building rtems by manually downloading them from the http
link.It was working fine but then in
           building: sparc-rtems4.11-binutils-2.24-x86_64-linux-gnu-1
It took a lot of time about 30 minutes.It was then that i terminated the
process using ctrl +Z.From then on whenever i am rebuilding,I get this error
error: copying tree:
/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.11-binutils-2.24-x86_64-linux-gnu-1-root-sambeet/home/sambeet/development/rtems/4.11/bin/sparc-rtems4.11-as
/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-sambeet/4.11/rtems-sparc/home/sambeet/development/rtems/4.11/bin/sparc-rtems4.11-as:
[Errno 26] Text file busy:
'/home/sambeet/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-sambeet/4.11/rtems-sparc/home/sambeet/development/rtems/4.11/bin/sparc-rtems4.11-as'
Build Set: Time 0:05:49.468578
Build FAILED
Can you please help me
URL: <http://lists.rtems.org/pipermail/users/attachments/20151208/be001869/attachment.html>
