Beaglebone Bootloader
Cláudio Silva
claudiodcsilva at gmail.com
Mon Jun 22 08:39:49 UTC 2015
Hi Angelo,
xkyboot is just a command name that is executed by uenvcmd; you can name
whatever you want. "XKYAPP2" is the executable name. It should placed on
the tftp server's root, or otherwise you need to provide the full path to
it.
Is your tftp server working correctly? Try to test from a tftp client on
Linux.
Best Regards,
Cláudio
On Mon, Jun 22, 2015 at 6:51 AM Angelo Fraietta <
newsgroups at smartcontroller.com.au> wrote:
> I am using BBB also
> I have had a look at what you have provided
> are XKYAPP2 and xkyboot your app names?
> Lets say I wanted to boot ticker from tftp server (assume my tftp server
> has same ip address as yours)
> I have copied
> development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/samples/ticker/ticker.exe
> to the root of my tftp server
> I am assuming this is entire uEnv.txt What should it look like (I have
> provided whole of your file here). Thanks
> ### BBB : Configuration
> ipaddr=192.168.0.202
> serverip=192.168.0.2
> netmask=255.255.255.0
> ### XKY-OS : Configuration
> baseaddr=0x81000000
> application=/XKYAPP2
> ### Boot BBB from network
> nfsargs=setenv bootargs console=${console} root=/dev/nfs nfsroot=${serverip}:${rootpath} rw ip=${ipaddr}:${serverip}:${serverip}:${netmask}::eth0:off
> xkyboot=run nfsargs; tftp ${baseaddr} ${application}; bootm ${baseaddr}
> uenvcmd=run xkyboot
> On Fri, Jun 19, 2015 at 6:14 PM, Cláudio Silva <claudiodcsilva at gmail.com>
> wrote:
>> You should be able to boot RTEMS through TFTP. At least I do it in the
>> BBB, I assume the white version should work as well. You just have to
>> change uboot configuration and setup a tftp server.
>> My current uboot configuration is the following:
>> https://gist.github.com/cdcs/76c4dd49c2d574bd68cc
>> Cláudio
>> On Fri, Jun 19, 2015 at 5:57 AM Chris Johns <chrisj at rtems.org> wrote:
>>> On 19/06/2015 1:56 pm, Angelo Fraietta wrote:
>>> > Those links I posted -- do any of them work with RTEMS?
>>> I do not know. I have no interested uboot. Maybe someone else knows.
>>> Chris
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20150622/8a5520d5/attachment-0001.html>
