gsoc students
Andrew Harris andrew.unit at gmail.com
Fri Jun 5 15:46:31 UTC 2015
Hi Gedare,
   No I didn't know about the new framework in cpukit/dev/i2c.  I'll take a
look.  Also, don't let me hamper any work the students are doing.  I'm
working on getting it through public release, and I'm hopeful that I can
contribute it back, but it's possible that it can't be released for some
reason.  I'd hate to interfere with the work of the students in this case.
-andrew
On Wed, Jun 3, 2015 at 11:10 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Always glad to hear about possible code coming back out. Is your I2C
> driver using the newer driver framework in cpukit/dev/i2c?
> One student is working on networking with libbsd and with that might
> get USB for not much more effort. Another student is already working
> on the GPIO peripherals, and plans to work on ADC after that, so there
> won't be much duplication of effort.
> Gedare
> On Wed, Jun 3, 2015 at 10:48 AM, Andrew Harris <andrew.unit at gmail.com>
> wrote:
> > Hi,
> >    I was curious to see when they started and what they're going to work
> on.
> > I'm new to BSP development, but I have working drivers for I2C, GPIO and
> PWM
> > (I believe possibly for the BBBlack only).  Right now they're not
> building
> > in the normal BSP directory, but in my project directory.  So I probably
> > have a chunk of work still to do to get them building in the way the BSP
> > expects.  I'm hoping to get them released back to RTEMS, but I have to
> work
> > through my employer's public release process first.  I was curious to see
> > when the students were going to start and what they were going to work
> on.
> > I see one of the students would be working on the network stack.  If the
> > other student worked on the ADC and USB drivers before working on I2C and
> > GPIO, maybe we could avoid some duplication of effort.  Just a
> suggestion.
> > -andrew
> > On Wed, Jun 3, 2015 at 9:11 AM, Joel Sherrill <joel.sherrill at oarcorp.com
> > wrote:
> >> On June 3, 2015 9:07:23 AM EDT, Anand Krishnan <anandkp92 at gmail.com>
> >> wrote:
> >> >Hi,
> >> >The students have already started the  work. You can follow their
> >> >progress at : https://devel.rtems.org/wiki/GSoC/2015
> >> They are collectively adding device drivers to the BB BSP which already
> >> supported all variants.
> >> Andrew. What drivers are you must interested in?
> >> >Thanks!
> >> >Anand
> >> >On Wed, Jun 3, 2015 at 6:17 PM, Andrew Harris <andrew.unit at gmail.com>
> >> >wrote:
> >> >Hi,
> >> >I'm curious when the GSOC students will be starting work on the
> >> >beaglebone BSP.  Does anyone have an idea?
> >> >thanks,
> >> >-andrew
> >> >_______________________________________________
> >> >users mailing list
> >> >users at rtems.org
> >> >http://lists.rtems.org/mailman/listinfo/users
> >> --joel
> > users mailing list
> > users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20150605/633aa426/attachment-0002.html>
