RTEMS ARM build fails, timespec2bintime
Mon May 25 02:51:37 UTC 2015
On May 24, 2015 9:13:24 PM CDT, Robert Perez <robertperez67 at hotmail.com> wrote:
>Hi everyone, I'm trying to build RTEMS for the beaglebone using this
>tutorial
>http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
>but when executing the make command some errors are appearing regarding
>the timespec2bintime function, seems not to be declared, also some
>related structs are not recognized (please see the attachment)
>I've seen in https://sourceware.org/ml/newlib/2015/msg00186.html and
>https://devel.rtems.org/ticket/2271 changes that could be related to
>this error as I understand, but I'm new with RTEMS and I'm stuck at
>this now.
>Also tried to build using the raspberry pi with this other tutorial
>http://alanstechnotes.blogspot.com/2013/03/compiling-and-installing-rtems-for.html
>and the same happens.
>Any helps is appreciated.
This stuff was added to newlib recently. You need a new toolset. Update the RSB, build tools and you will be OK.
I promise I have built every BSP in the last week.
>Regards, Robert.
--joel
