[GSoC Project Announce] Support Strong APA Scheduling in SMP Configurations
Darshit Shah
darnir at gmail.com
Mon Apr 25 00:00:03 UTC 2016
Hi,
I'd like to introduce myself and the project that I'll be working on
over the next couple of months with RTEMS under the Google Summer of
Code program.
** Project Abstract **
RTEMS exposes a Linux-like Arbitrary Processor Affinity (APA) API that
allows applications to restrict themselves to being scheduled on only a
subset of the available processor cores. However, the current priority
SMP scheduler is not very efficient at this task. Hence, the aim of this
project is to implement a new scheduling policy that works similar to
the priority scheduler but includes an efficient way to provide Strong
APA scheduling using a bipartite graph as described in [1].
This project will help RTEMS gain a better SMP scheduler that requires
significantly lesser overhead for scheduling. The new algorithm should
cause a scheduling overhead of O(m^2) where m is the number of
processors in the system, whereas the existing algorithm causes
overheads greater than O(n^2) where n is the number of tasks in the
system.
The proposal which outlines the exact scope and other details of this
project can be found at [2].
I would appreciate any suggestions / ideas about this project from your
side as well. Also, do let us know if you think this will be useful to
you in the future and how you plan on using it.
[1]: http://www.mpi-sws.org/~bbb/papers/pdf/rtss14f.pdf
[2]:
https://docs.google.com/document/d/1kYjC3LT9piCXwMP1mTrBKRgYpMpuwVpu-t7OAPOKxF8/edit?usp=sharing
Thanking You,
Darshit Shah
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20160425/72e80728/attachment.bin>
