RTEMS AMP with Petalinux
Badr El Hiouel
elh.badr at gmail.com
Mon Apr 18 14:57:50 UTC 2016
Hi,
Is the default mode AMP or SMP for RTEMS ? How can the AMP configuration of
RTEMS be enabled ?
The OpenAMP framework doesn't support RTEMS.
I'm thinking to configure Petalinux on "maxcpu = 1" and to launch RTEMS on
second cpu. I'm just afraid from memory and adresses problems.
What do you think about this ? Has anybody tried to launch RTEMS via
Petalinux ?
Thank you
________
*Badr EL HIOUEL*
Mail : elh.badr at gmail.com
2016-04-15 2:07 GMT+02:00 Joel Sherrill <joel at rtems.org>:
> On Apr 14, 2016 6:30 PM, "Chris Johns" <chrisj at rtems.org> wrote:
> > On 15/04/2016 07:24, Badr El Hiouel wrote:
> >> I have RTEMS working on my Zedboard
> > Well done.
> >> and now I want to run RTEMS with an
> >> AMP configuration : Petalinux on cpu 0 & RTEMS app on cpu 1.
> > Oh nice.
> >> Has anybody managed to get this working on zedboard ?
> >> Do you have any suggestion to this issue?
> > I suggest you reference the Linux kernel support and see what is needed.
> Coping GPL code means the code will not be accepted into RTEMS so you need
> to implement things yourself. I think the Xilinx demos are based around
> FreeRTOS so again be careful of the licenses for this code. If the license
> here is not suitable then I suggest you do not reference or follow that
> code so any work you do is not tainted. Also please send me a private email
> if there are license issues and we can take this off list.
> The OpenAMP project may be of interest although it is not directly
> applicable here.
> https://github.com/OpenAMP/open-amp
> There may be some expertise in that community anyway.
> --Joel
> > Chris
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20160418/28506998/attachment-0002.html>
