How to compile testsuites in RTEMS main tree
Fri Aug 12 08:10:42 UTC 2016
On 12/08/16 10:08, xuelin.tian at qkmtech.com wrote:
> I want to compile the testsuites in "rtems/testsuites/libtests" for
> example, however, I don't find any Makefile in it. The right way to do
> is to use the "configure" command to build the samples, am I correct?
> Here comes the question, is it the same way to run "configure" as
> building RTEMS, like, "./configure --prefix=... --rtems-bsp=..."?
Please add "--enable-tests" to your top level configure command line.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
