Build of example fails with waf
Gene Smith gds at chartertn.net
Thu Aug 25 20:10:01 UTC 2016
On 08/25/2016 02:44 AM, Chris Johns wrote:
> On 25/08/2016 4:42 PM, Gene Smith wrote:
>> On 08/25/2016 02:01 AM, Chris Johns wrote:
>>> What happens if you remove --rtems-archs=arm from the configure command
>>> line and just specify the BSP? The BSP name includes the arch.
>> Same result. I actually added that later to try to fix the error.
> I will take a look.
> Chris
I found the problem. The rtems.py submodule code defaults the rtems
version to 4.11. So when I add the option --rtems-version=4.12 the
configuration runs.
This probably should be mentioned in the README.waf of examples-v2.
-gene
