RSB fails for 4.10 and 4.9
Gerald Needell
jerry.needell at unh.edu
Fri Feb 26 16:36:54 UTC 2016
I have been experimenting with the RTEMS Source Builder under CENTOS7
4.11 builds just fine as described on the wiki.
I run into the same failure for 4.10 and 4.9
( I have gotten past the texinfo issues ...)
The problem appears to be with git trying to download the rtems-kernel.
Is there some extra step need for 4.10 or 4.9?
Error messages:
config: tools/rtems-kernel-4.10.2.cfg
package: sparc-rtems4.10-kernel-4.10.2-1
git: reset: git://git.rtems.org/rtems.git
git: checkout: git://git.rtems.org/rtems.git => 4.10.2
git: pull: git://git.rtems.org/rtems.git
error: git command failed (/usr/bin/git): 1
Build FAILED
Thanks
Jerry
