Compiling RTEMS
soja-lists at aries.uberspace.de soja-lists at aries.uberspace.de
Wed Mar 16 08:20:38 UTC 2016
Am 2016-03-16 01:45, schrieb Wang, John (IVV-1800):
> Hi,
> I am attempting to build RTEMS in Ubuntu.  The version I am using is
> from Gaisler - 4.10-1.2.16.
> I am run the bootstrap, and configure command with no issues.
> However, when I run the make / gmake I command I receive the following
> error:
> Checking for sparc-rtems4.10-gcc... no
> No acceptable cc found in $PATH
The RTEMS sources alone are not enough. Do you have a working
cross-compiler?
You can either download the prebuilt one from gaisler or build one using
the rtems-source-builder.
If you already have one, you might have simply forgotten to add the
location to your PATH environment variable.
Cheers,
    Jan
> Can anyone help me with this?
> Thank you
> devel mailing list
> devel at rtems.org
