Follow-up: RTEMS Project Documentation repository available.
Fri Sep 9 03:40:28 UTC 2016
On 09/09/2016 11:34, Gene Smith wrote:
> On 05/19/2016 11:48 PM, Chris Johns wrote:
>> The rtems-docs.git repo source is all ReST format and built using
>> Spinix. There are waf scripts in each directory so just drop into the
>> manual's directory enter 'waf configure' and 'waf' to build. To build
>> PDF use 'waf --pdf'.
>> To build you will need to install Spinix and for PDF you will need to
>> Tex, Latex etc. On FreeBSD this is the texlive-all package. I hope Linux
>> users will chime in with the packages needed.
> Tried to build the eclipse manual in latest rtems-docs on Fedora 23:
> 1) waf configure said the sphinx programs was too old. Had to uninstall
> the fedora sphinx package and install the lastest with
> sudo pip install -U sphinx
This is good to know.
> 2) which allows waf configure to work but with some missing items:
> [gene at hplt eclipse]$ waf configure
> Setting top to                           :
> /home/gene/rtems/rtems-docs/eclipse
> Setting out to                           :
> /home/gene/rtems/rtems-docs/eclipse/build
> Checking for program 'tex'               : /usr/bin/tex
> Checking for program 'latex'             : /usr/bin/latex
> Checking for program 'pdflatex'          : /usr/bin/pdflatex
> Checking for program 'xelatex'           : not found
> Checking for program 'bibtex'            : /usr/bin/bibtex
> Checking for program 'dvips'             : /usr/bin/dvips
> Checking for program 'dvipdf'            : /usr/bin/dvipdf
> Checking for program 'ps2pdf'            : /usr/bin/ps2pdf
> Checking for program 'makeindex'         : /usr/bin/makeindex
> Checking for program 'pdf2ps'            : /usr/bin/pdf2ps
> Checking for program 'makeglossaries'    : not found
> Checking for program 'sphinx-build'      : /usr/bin/sphinx-build
> Checking for program 'aspell'            : /usr/bin/aspell
> Checking for program 'inliner'           : not found
> Checking if Sphinx is at least 1.3       : yes (1.4.6)
> 'configure' finished successfully (0.341s)
> 3) running waf I see a crash-like error:
> Waf: Entering directory `/home/gene/rtems/rtems-docs/eclipse/build'
> [6/6] Processing
> /home/gene/rtems/rtems-docs/eclipse/build/html/index.html: glossary.rst
> index.rst overview.rst rtems.rst -> build/html/index.html
> Waf: Leaving directory `/home/gene/rtems/rtems-docs/eclipse/build'
> Build failed
> Traceback (most recent call last):
>     File
> "/home/gene/bin/.waf-1.9.3-81a83addbb9dd6b696b76d32d6fa8a8e/waflib/Task.py",
> line 138, in process
>       ret=self.run()
>     File "<string>", line 6, in f
>     File
> line 94, in get_cwd
>       self.generator.bld.fatal('Working folders given to tasks must be
> Node objects')
>     File
> "/home/gene/bin/.waf-1.9.3-81a83addbb9dd6b696b76d32d6fa8a8e/waflib/Context.py",
> line 251, in fatal
>       raise self.errors.ConfigurationError(msg,ex=ex)
> ConfigurationError: Working folders given to tasks must be Node objects
> Any ideas? (waf works OK when running RSB or example-v2 apps).
Thank you for testing and reporting. It seems something in waf-1.9.3 has
changed and exposed an issue in the doc build system. Amar put the build
system together and I am not sure what has broken.
