configure problem
Tue Dec 26 21:55:52 UTC 2017
Again, please do not post user questions to builds at rtems.org, it is for build
results and not user questions. Thanks.
On 26/12/17 10:49 pm, bin.wang at qkmtech.com wrote:
> i has find this problem is caused by "rtems tools path is not correct"
> but when i set the path ok ,there is another problem
Please remove any reference to any Xilinx SDK tools from your path while you are
building the tools. You need to use MSYS2 to build the tools.
> G:\software\xilinx\SDK\2017.3\gnuwin\bin\rm.exe: cannot remove `*.core': Invalid argument
The Xilinx SDK contains it's own environment and this will not be able to build
a set of GCC tools.
