RTEMS tools invalid version file
Heinz P. Junkes junkes at fhi-berlin.mpg.de
Tue Oct 30 07:38:17 UTC 2018
It's on a freshly updated ubuntu 18.04.1 (This was a fault, i know ;-) )
Its python 2.7:
[h1 at earth rtems-tools (master *)]$ python -v
# installing zipimport hook
import zipimport # builtin
# installed zipimport hook
# /usr/lib/python2.7/site.pyc matches /usr/lib/python2.7/site.py
import site # precompiled from /usr/lib/python2.7/site.pyc
# /usr/lib/python2.7/os.pyc matches /usr/lib/python2.7/os.py
import os # precompiled from /usr/lib/python2.7/os.pyc
import errno # builtin
The bulder works on my osx system.
Heinz
On 10/30/18 1:20 AM, Chris Johns wrote:
> On 29/10/2018 23:03, Heinz P. Junkes wrote:
>> Try to run waf in rtems tools:
>> [h1 at earth rtems-tools (master)]$ ./waf configure
>> --prefix=/home/h1/RTEMS/rtems/5.0 build install
>> Setting top to                           : /home/h1/RTEMS_DEV/rtems-tools
>> Setting out to                           : /home/h1/RTEMS_DEV/rtems-tools/build
>> invalid version file: error: Invalid revision config value:
>> /home/h1/RTEMS_DEV/rtems-tools/config/rtems-version.ini: 0.not_released:
>> descriptor 'isdigit' requires a 'str' object but received a 'unicode'
>> (complete log in /home/h1/RTEMS_DEV/rtems-tools/build/config.log)
>> [h1 at earth rtems-tools (master)]$ more
>> # project  configured on Mon Oct 29 12:58:24 2018 by
>> # waf 1.9.9 (abi 99, python 2070fc1 on linux2)
>> # using ./waf configure --prefix=/home/h1/RTEMS/rtems/5.0 build install
>> Setting top to
>> Setting out to
>> from /home/h1/RTEMS_DEV/rtems-tools: Could not load the Waf tool 'doxygen' from
>> ['/home/h1/RTEMS_DEV/rtems-tools/.waf-1.9.9-75529a659e4f06cb4254801e52405e0a', '/
>> home/h1/RTEMS_DEV/rtems-tools',
>> '/usr/local/lib/python2.7/dist-packages/setuptools-18.0.1-py2.7.egg',
>> '/usr/local/lib/python2.7/dist-packages/pyepics-3.2.4-py2.7
>> .egg', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
>> '/usr/lib/python2.7/lib-dynlo
>> ad', '/home/h1/.local/lib/python2.7/site-packages',
>> '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages',
>> es/gtk-2.0', '/usr/lib/python2.7/dist-packages/wx-3.0-gtk3']
>> No module named doxygen
>> from /home/h1/RTEMS_DEV/rtems-tools: invalid version file: error: Invalid
>> revision config value: /home/h1/RTEMS_DEV/rtems-tools/config/rtems-version.ini:
>> 0.not_r
>> eleased: descriptor 'isdigit' requires a 'str' object but received a 'unicode'
> Amar mentioned something about this in a chat the other day and I have not
> chased it up.
> Maybe he has something to add which could help?
> Which version of python do you have installed?
>> No idea about doxygen, but this is installed on the system I am using:
>> [h1 at earth rtems-tools (master)]$ which doxygen
>> /usr/bin/doxygen[h1 at earth rtems-tools (master)]$ doxygen
>> error: Doxyfile not found and no input file specified!
>> Doxygen version 1.8.13
>> Copyright Dimitri van Heesch 1997-2015
>> You can use doxygen in a number of ways:
> Hmm I am not sure where this dependency on doxygen comes from.
> Chris
Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)
[General Data Protection Regulation (GDPR)] der Europaeischen Union.
