RTEMS tools invalid version file
Tue Oct 30 02:10:00 UTC 2018
On 30/10/2018 13:06, Amar Takhar wrote:
> On 2018-10-30 11:20 +1100, Chris Johns wrote:
> <snip>
>> Amar mentioned something about this in a chat the other day and I have not
>> chased it up.
> <snip>
> This is quick since it's late but the issue I ran into is in
>   rtemstoolkit/version.py
> In line 174: -- if that's the latest
>   _revision = int(''.join(itertools.takewhile(str.isdigit, rev)))
> Depending on the version of Python you are running 'rev' can be unicode() or
> str().  The operation being run is not valid for unicode.
> The fix I did to solve this issue was to coerce it to str()
> _revision = int(''.join(itertools.takewhile(str.isdigit, str(rev))))
> This should be harmless since the value is always a string anyway so no data
> will ever be lost.
Thanks. I will patch the code.
