building powerpc-rtems5-gcc-7.3.0-newlib on Darwin Build FAILED
Wed Oct 31 11:55:11 UTC 2018
On 31/10/2018 12:49, Heinz Junkes wrote:
> Hello Sebastian,
> it worked with the patch. Thank you.
Thanks for testing.
> What I don't understand is why I could build the gcc-7.3 under linux (with the rtems-source-builder) and
> not with the Mac (darvin)?
> Shouldn't the same gcc tarball be loaded when downloading?
The GCC archive is the same, yes. What was different is the ISL version
installed on the host. With the patch a particular ISL version is used
which is statically linked.
https://devel.rtems.org/ticket/3577
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
