Console API
Ярослав Лещинский midniwalker at gmail.com
Fri Oct 26 15:27:02 UTC 2018
> I think you are referencing the right documentation.
> "rtems_termios_callbacks" should be what you need.
I found another one: rtems_termios_device_handler  -- is it the same as
rtems_termios_callbacks?
Would you tell me what exact platform you are working on? I recommend you
> read the bsp source code that is mostly close to yours.
I'm adding stm32l476 dev board as rtems bsp. And yes I checked stm32f4
implementation first and a couple of another arm BSP's.
Anyway thank you for your answer.
On Fri, 26 Oct 2018 at 18:06, Mingyu Li <lmy2010lmy at gmail.com> wrote:
> Hi,
> Please feel free to ask.
> Best regards,
> Maxul
> Ярослав Лещинский <midniwalker at gmail.com> 于2018年10月26日周五 上午12:18写道:
>> Hello,
>> I'm working with a new BSP and now trying to add console implementation.
>> I'm working on 4.11 branch.
>> During the last try I've got such error:
>> *error: unknown type name 'rtems_termios_handler'*
>>  Although the documentation here:
>>  https://docs.rtems.org/releases/rtems-docs-4.11.2/bsp-howto/console.html
>> uses exactly such type name.
>> Seems like I'm using the outdated API documentation. Could you please
>> provide some info where I can get the actual reference documentation about
>> 4.11 RTEMS Api.
>> Thank you a lot.
>> Kind regards,
>> *Yaroslav Leshchinsky*
>> users mailing list
>> users at rtems.org
Kind regards,
URL: <http://lists.rtems.org/pipermail/users/attachments/20181026/28695514/attachment-0002.html>
