RTEMS tools invalid version file
Heinz Junkes junkes at fhi-berlin.mpg.de
Tue Oct 30 10:02:56 UTC 2018
The patch from Amar works for me.
This is quick since it's late but the issue I ran into is in
 rtemstoolkit/version.py
In line 174: -- if that's the latest
 _revision = int(''.join(itertools.takewhile(str.isdigit, rev)))
Depending on the version of Python you are running 'rev' can be unicode() or
str().  The operation being run is not valid for unicode.
The fix I did to solve this issue was to coerce it to str()
_revision = int(''.join(itertools.takewhile(str.isdigit, str(rev))))
This should be harmless since the value is always a string anyway so no data
will ever be lost.
Thanks a lot for your great and fast support.
Heinz
> Amar mentioned something about this in a chat the other day and I have not
> chased it up.
Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)
[General Data Protection Regulation (GDPR)] der Europaeischen Union.
