Init task
Mon Aug 5 05:23:07 UTC 2019
Hello Yaron,
On 04/08/2019 15:05, yaron o wrote:
> hello all,
> In my application i am using  rtems_task Init(rtems_task_argument
> argument) as my main (and only) task and that is where the application
> start to work , i want to add one more task with the lowest priory.
> my first question is what is the priority of the Init Task ?
the default priority is 1, you can change it via configuration options:
https://docs.rtems.org/branches/master/c-user/configuring_a_system.html#classic-api-initialization-tasks-table-configuration
> and second if i create one more task, i will have two tasks (init and
> new one) in my application that switch according to the priority?  or
> the Init task will not longer exist ( because i'm not creating it i just
> call it in the begging with the command  rtems_task
> Init(rtems_task_argument argument)   )?
Task switching is always done by priority, however, in uniprocessor
configurations the Init task is non-preemptible by default.
https://docs.rtems.org/branches/master/c-user/task_manager.html#task-mode
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
