Python.h
Dudley, David dudleyd at frib.msu.edu
Tue Dec 17 16:48:58 UTC 2019
OK, trying to setup source builder using the 'Quick Start' in the documentation set.
Building on "Linux  4.9.0-9-amd64 #1 SMP Debian 4.9.168-1+deb9u5 (2019-08-11) x86_64 GNU/Linux"
Get down to "2.4. Install the Tool Suite"
Run the command "../source-builder/sb-set-builder --source-only-download 5/rtems-sparc"
It fails with
"config: tools/rtems-gdb-8.3-1.cfg
error: config error: gdb-common-1.cfg:99: "gdb: python: header file not found: python2.7/Python.h, please install"
Following instructions exactly, on fresh system, no go.
Ideas?
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7133
Email: dudleyd at frib.msu.edu<mailto:dudleyd at frib.msu.edu>
[cid:image002.jpg at 01D07041.57B6D750]
URL: <http://lists.rtems.org/pipermail/users/attachments/20191217/f1f9ca02/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.rtems.org/pipermail/users/attachments/20191217/f1f9ca02/attachment-0001.jpg>
