Creating older RTEMS5 tools
Ian Caddy
ianc at goanna.iinet.net.au
Mon Jan 14 00:53:45 UTC 2019
On 12/01/2019 6:45 am, Joel Sherrill wrote:
> I assume it would be OK to change:
> tools/rtems-binutils-2.31.1
> tools/rtems-gcc-7.4.0-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f
> back to:
> tools/rtems-binutils-2.30
> tools/rtems-gcc-7.3.0-newlib-3.0.0
> I am going to attempt this, but if there is a better way, I would
> more
> than happy to try it.
> If the files you are referencing haven't been removed, then this
> should work. But checking out the RSB from the appropriate date would
> be better.
The problem is this is for MSYS2 on Windows and RSB on that platform was
having issues with Python at the time. Those have all been resolved
now, so the newer RSB seems to be the only way forward.
regards,
Ian C.
URL: <http://lists.rtems.org/pipermail/users/attachments/20190114/adda0e92/attachment-0002.html>
