Problems running RTEMS on Raspberry Pi2
Thu Jul 25 08:03:10 UTC 2019
On 24/7/19 11:26 pm, Jan.Sommer at dlr.de wrote:
> Hello,
> We are having troubles getting RTEMS to run on the RPi2.
> We built the BSP from current master and used the firmware of a recent Raspbian on the SD-Card, but could not manage to get any output on the UART.
> We also tried to use an older version of the firmware as mentioned here by Alan (https://lists.rtems.org/pipermail/users/2017-July/031481.html) .
> With u-boot we managed to start ticker.exe with the bootelf command and sometimes get a fatal error on the uart, but the output is garbled, so there is no useful debugging information.
> Can someone build and run the current master for the RPi2 successfully?
I can build and can confirm something is broken. I get no output from a RPi2.
