CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER macro issue
Michel Macena mmacena.eng at gmail.com
Wed Jul 24 18:58:00 UTC 2019
Thanks for the answer.
Sorry for my ignorance but I can't see how is this related with my
problem.  I didn't get the "Create bad task" problem. Also there is no
fatal error with code 20.
Em qua, 24 de jul de 2019 às 02:46, Sebastian Huber <
sebastian.huber at embedded-brains.de> escreveu:
> On 23/07/2019 21:30, Michel Macena wrote:
> > Hi, I have compiled a test code for an ERC32 target board and loaded it
> > using gdb,
> > the code:
> >     #include <bsp.h>
> >     #include <stdlib.h>
> >     #include <stdio.h>
> >     rtems_task Init(
> >        rtems_task_argument ignored
> >          uint16_t a=6;
> >          printf( "Hello World Michel\n" );
> >          printf( "numero: %d\n",a );
> Please have a look at the INTERNAL_ERROR_THREAD_EXITTED fatal error
> description:
> https://docs.rtems.org/branches/master/c-user/fatal_error.html#internal-error-codes
> If you use GDB, then always set a break point to _Terminate. It will hit
> if the application terminated.
URL: <http://lists.rtems.org/pipermail/users/attachments/20190724/c8c27672/attachment-0002.html>
