shell output
Jonathan Brandmeyer
jbrandmeyer at planetiq.com
Fri Nov 1 14:50:25 UTC 2019
cpukit/libmisc/shell/ has many of the entry points for the shell functions.
On Fri, Nov 1, 2019 at 6:39 AM <mbenson at windhoverlabs.com> wrote:
> I take it that’s a no on the documentation. Can somebody just tell me
> what these mean or point me where in the code it is? It’s not an easy
> follow.
> Sent from my iPhone
> On Oct 31, 2019, at 13:43, Mathew Benson <mbenson at windhoverlabs.com>
> wrote:
> is there any documentation that explains the actual output of the shell
> commands? For example, the documentation for the task command says how to
> run it, and gives the following sample output:
> SHLL [/] # task
> ID NAME SHED PRI STATE MODES EVENTS WAITINFO
> 0a010001 UI1 UPD 254 EV P:T:nA NONE
> 0a010002 SHLL UPD 100 READY P:T:nA NONE
> But doesn't actually explain what the data in the columns mean. What do
> the following "STATE" values mean: EV, SIG:IS, READY, MSG, SEM, and TIME?
> What do the MODES mean? Same question for the "sema" command output.
> *Mathew Benson*
> CEO | Chief Engineer
> Windhover Labs, LLC
> 832-640-4018
> www.windhoverlabs.com
> users mailing list
> users at rtems.org
Jonathan Brandmeyer
Vice President of Software Engineering
PlanetiQ
URL: <http://lists.rtems.org/pipermail/users/attachments/20191101/b7f6ce6d/attachment.html>
