jtag access for zybo zynq board
Jonathan Brandmeyer
jbrandmeyer at planetiq.com
Fri Sep 27 17:22:39 UTC 2019
OpenOCD should work, although you'll have to do some legwork on your
own to make it happen. It has JTAG adapter configurations built-in
for the HS3 family, as well as some of the Zynq-7000 family. It
doesn't have board files for the COTS dev boards, though.
My workflow to bring up a board from scratch was:
- Configure and build a minimal bitstream and FSBL using XIlinx Vivado
and SDK, respectively.
- Boot the target to JTAG mode. Read the Zynq-7000 TRM section on the
boot process to see how the boot mode select pins work with the ROM
Bootloader's flow, as well as your board's schematic.
- Load the FSBL into OCM and run it. In the default configuration, it
should remain in JTAG mode. At this point, ps7_init (PS I/O pin
configuration) and DDR init should be done. It is possible to perform
I/O initialization directly from OpenOCD and Vivado's TCL, but we
didn't bother with that workflow.
- Load programs into DDR and run those. For your workflow, it may be
the initial load of u-boot which you use to initialize your flash
memories. You could also load an RTEMS program directly to DDR
instead.
See also https://devel.rtems.org/wiki/Debugging/OpenOCD/Xilinx_Zynq I
didn't follow his process exactly, but found it quite informative.
Upstream OpenOCD provides an adequate Zynq-7000 target file nowadays.
An example board file for the microzed with an HS3 JTAG:
source [find interface/ftdi/digilent_jtag_hs3.cfg]
transport select jtag
reset_config srst_only srst_push_pull
source [find target/zynq_7000.cfg]
# The adapter needs to be extra slow until PS clocks are all the way
up. Can raise to 20 MHz after running the FSBL
adapter_khz 2000
I'm using the same target/zynq_7000.cfg supplied with OpenOCD, except
that I add the following utility function:
proc zynqpl_reset_release {target} {
# Unlock SLCR
$target mww 0xf8000008 0xdf0d
# Enable level shifters, both PL-PS and PS-PL
$target mww 0xf8000900 0xF
# Release FPGA reset
$target mww 0xf8000240 0x0
# Lock SLCR
$target mww 0xf8000004 0x767b
A script to load an execute everything from the reset condition on the
microzed looks like this. Obviously those paths are to artifacts of
our specific build system, but hopefully this can serve as a
jumping-off point for you.
# Load the FSBL into OCM and run it.
init
halt
targets zynq.cpu0
load_image arm-none-eabi/bin/microzed_usrp_fsbl.elf 0x000 elf
resume 0
sleep 2000
halt
adapter_khz 20000
# FPGA fabric sequence.
zynqpl_program zynq_pl.bs
pld load 0 fsbl/microzed_usrp_platform/microzed_top.bit
sleep 100
zynqpl_reset_release zynq.cpu0
# At this point, MIO, EMIO, and DDR are all set up. Load the
application program into
# DDR.
load_image arm-rtems5/bin/microzed-rtems.elf
# Force ARM core state in case the halt was in Thumb mode.
arm core_state arm
resume 0x104040
HTH,
Jonathan Brandmeyer
PlanetiQ
