source-builder want to add CFLAG
Gedare Bloom
gedare at rtems.org
Fri Apr 24 17:02:04 UTC 2020
On Fri, Apr 24, 2020 at 9:40 AM Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
> Great, thanks. Now I have a new error, but the setting of CFLAG worked.
> I had always done "something" wrong and then didn't even look at the examples anymore.
> Danke Heinz
Bitte. The documentation here is a bit challenging yet. If you find
anything useful out, please share. If you think it makes sense, maybe
adding a way to pass some customization flags through the RSB command
line might make sense. Would have to discuss that with Chris.
> > On 24. Apr 2020, at 16:47, Gedare Bloom <gedare at rtems.org> wrote:
> > Heinz,
> > Did you try to modify the source-builder/config/ntp-4-1.cfg file to
> > add CFLAGS to it? You can see other examples in the same config folder
> > where CFLAGS are customized that might work to try.
> > Gedare
> > On Fri, Apr 24, 2020 at 8:02 AM junkes <junkes at fhi-berlin.mpg.de> wrote:
> >> I want to add the CFLAG "-DHAVE_MKTIME=1" to the source-builder process
> >> to build ntp
> >> ../source-builder/sb-set-builder --log=log_ntp_arm.txt
> >> --prefix=/home/h1/GSOC/RTEMS/5.0.0-m2003 \
> >> --host=arm-rtems5 --with-rtems-bsp=xilinx_zynq_a9_qemu net/ntp
> >> I have already tried several places (cfg-files) but without success.
> >> Danke,
> >> Heinz
> >> _______________________________________________
> >> users mailing list
> >> users at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/users
