Question about SIS for RTEMS 5 and timing
Fri Aug 7 14:30:44 UTC 2020
On Thu, Aug 6, 2020 at 3:54 PM Fabrício de Novaes Kucinskis <
fabricio.kucinskis at inpe.br> wrote:
> Hello all, I hope everyone on the list is health and safe.
> I’m studying the update of a SPARC project, currently based on RTEMS 4.11,
> to RTEMS 5.
> After installing RTEMS 5, the first thing I did was compile and run, on
> SIS, a set of example applications.
> When calling sparc-rtems5-sis, I noticed that the loaded application run
> fast as hell, as SIS was just calling one instruction after the other, with
> no timing concerns – different from what I saw on older versions.
> I’ve tried to set the frequency with the “-freq” parameter, but this makes
> no difference. I also checked the RTEMS SPARC BSP sources, and the
> CLOCK_SPEED definition inside the trap table is still set to 10, as ever.
> Can anyone say what is different between the previous and current SIS
> versions, and how can I make the applications run with a reasonable timing?
AFAIK sis is cycle accurate for the instructions inside its simulated
world. But the erc32 is VERY slow compared to the host processor and
simulated code runs incredibly fast. 1 second of erc32 CPU time takes much
less time to simulate.
There is a perf command in sis to get the view of the simulated CPU time.
I've cc'ed Jiri so he can add anything.
> Thanks in advance and best regards,
> Fabrício.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200807/394a38a6/attachment.html>
