users Digest, Vol 167, Issue 8
Zacchaeus Liang
zliang111 at gmail.com
Tue Aug 11 01:44:43 UTC 2020
Do i add it as an argument and what is the argument name (didn't reply all
sorry?
Thanks
zack
Il giorno lun 10 ago 2020 alle ore 21:31 Vijay Kumar Banerjee <
vijay at rtems.org> ha scritto:
> On Tue, Aug 11, 2020 at 6:57 AM Zacchaeus Liang <zliang111 at gmail.com>
> wrote:
> > It says that there is not supplied executable
> Looks like you're in the right direction.
> Add the location to the samples directory to the command line and
> it'll work. The location will be in the bsp build location.
> something like pc-386/i386-rtems5/c/pc386/testsuites/samples
> Best regards,
> Vijay
> > zack
> > Il giorno lun 10 ago 2020 alle ore 21:10 Vijay Kumar Banerjee <
> >> Hi Zack,
> >> I have posted a comment below...
> >> On Tue, Aug 11, 2020 at 5:54 AM Zacchaeus Liang <zliang111 at gmail.com>
> wrote:
> >> > I tried to add the prefix and i had the prefix with this
> >> > rtems-test --rtems-bsp=i386-rtems5
> --rtems-tools=$HOME/development/rtems/5
> --rtems-prefix=$HOME/development/rtems/5
> >> > i get the same error. Was the prefix correct based on the
> instructions?
> >> > Thanks
> >> > zack
> >> > Il giorno lun 10 ago 2020 alle ore 00:31 Niteesh G. S. <
> niteesh.gs at gmail.com> ha scritto:
> >> >> Hello,
> >> >>> Hello,
> >> >>> I'm Zack and I'm currently finishing up my university degree in
> comp sci.
> >> >>> I'm really interested in aviation and aerospace systems. I want to
> get into
> >> >>> rtems to learn more about rtos and contribute to rtems !
> >> >>> Currently I'm trying to build rtems and test and bsp. Hoping to then
> >> >>> contribute. I followed one of you GSOC student's tutorials and
> tried to go
> >> >>> ahead. I'm trying to build the test the bsp right now.
> >> >>> here is his blog post
> https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
> >> >>> I tried to run the bsp testing like this and it says the ini file
> is not
> >> >>> found. Is this the right bsp argument? After this i'm going to
> try to
> >> >>> build an application and would like to know the right path to
> install it.
> >> >>> Any tips on looking for easy things to learn to patch? Thanks in
> advance i
> >> >>> know it's a handful for questions!
> >> >>> zakonrockets at zakonrockets-Inspiron-15-7000-Gaming
> :~/development/rtems/kernels-5/pcp-386$
> >> >>> RTEMS Testing - Tester, 5.0.not_released
> >> >>> Command Line: /home/zakonrockets/development/rtems/5/bin/rtems-test
> >> --rtems-bsp option should have the bsp and not the architecture.
> >> Please try --rtems-bsp=pc-qemu
URL: <http://lists.rtems.org/pipermail/users/attachments/20200810/450e4ae4/attachment-0001.html>
