BSP missing
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Thu Aug 27 03:47:06 UTC 2020
________________________________
From: users <users-bounces at rtems.org> on behalf of Zacchaeus Liang <zliang111 at gmail.com>
Sent: Thursday, August 27, 2020 7:00 AM
To: Jan.Sommer at dlr.de
Cc: RTEMS Users RTEMS
Subject: Re: BSP missing
'm currently getting an error that the arch and the bsp is not found
zakonrockets at zakonrockets-Inspiron-15-7000-Gaming:~/development/app/hello$ ./waf configure --rtems=$HOME/development/rtems/5 --rtems-bsp=pc386
Hi Zacchaeus, try using
--rtems-bsp=i386/pc386 instead of
--rtems-bsp=pc386.
I think it should work.
Thanks
Mritunjay Sharma
Try using
Setting top to : /home/zakonrockets/development/app/hello
Setting out to : /home/zakonrockets/development/app/hello/build
No valid arch/bsps found
(complete log in /home/zakonrockets/development/app/hello/build/config.log)
thanks zack
Il giorno mar 25 ago 2020 alle ore 17:04 <Jan.Sommer at dlr.de<mailto:Jan.Sommer at dlr.de>> ha scritto:
> I followed this tutorial from a GSOC student. https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
> This is how i've configured it.
> $HOME/development/rtems/rtems-5/configure --target=i386-rtems5 --enable-rtemsbsp=pc386 --enable-tests=samples --prefix=$HOME/development/rtems/5 --enable-cxx --enable-networking --enable-posix
Here you configure a build of the pc386 BSP.
> And i was able to test it with
> home/zakonrockets/development/rtems/5/bin/rtems-test --rtems-tools=/home/zakonrockets/development/rtems/5 --rtems-bsp=pc-qemu /home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites --rtems-prefix=/home/zakonrockets/development/rtems/5
> I don't quite know the name of my BSP currently I think it's pc 386 but it's not found. Am a correct to assume that it is?
Yes, it should be the pc386 BSP.
What do you mean by it is not found? If you search for "ticker.exe" do you find the testsuites/samples directory which should contain it?
Best regards,
Jan
> Il giorno mar 25 ago 2020 alle ore 16:17 <Jan.Sommer at dlr.de<mailto:Jan.Sommer at dlr.de>> ha scritto:
> > -----Original Message-----
> > From: users [mailto:users-bounces at rtems.org<mailto:users-bounces at rtems.org>] On Behalf Of Gedare Bloom
> > Sent: Tuesday, August 25, 2020 9:15 PM
> > To: Zacchaeus Liang
> > Hi Zack,
> > On Tue, Aug 25, 2020 at 1:02 PM Zacchaeus Liang <zliang111 at gmail.com<mailto:zliang111 at gmail.com>>
> > wrote:
> > > So I was able to build the bsp and all of the tests pass. I'm currently trying
> > to build the hello world app.
> > rtems=$HOME/development/rtems/5 --rtems-bsp=pc-qemu
> > > Setting top to :
> > > Setting out to :
> > > (complete log in
> > Is this from rtems-examples.git? Or something else?
> pc-qemu exists in a configuration for the rtems-tester, but it is only a different way to execute the pc686 binaries on qemu instead via tftp on actual hardware (for more see here: https://git.rtems.org/rtems-tools/tree/tester/rtems/testing/bsps/pc-qemu.ini).
> I haven't encountered it somewhere else.
> Best regards,
> Jan
> > Please check out rtems-examples.git/README.waf for some assistance on
> > how to use the rtems_waf to build an application.
> > > Thanks
> > > Zack
> > > _______________________________________________
> > > users mailing list
> > > users at rtems.org<mailto:users at rtems.org>
> > > http://lists.rtems.org/mailman/listinfo/users
> > users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20200827/c02e780d/attachment-0001.html>
