BSP missing
Zacchaeus Liang zliang111 at gmail.com
Fri Aug 28 19:55:18 UTC 2020
Thanks so much! I managed to get it to work! The strange thing was to run
it I had to use
/home/zakonrockets/development/rtems/5/bin/rtems-run
--rtems-bsps=pc-qemu  build/i386-rtems5-pc386/hello.exe
 It's wierd because i'm using that as opposed to the i386/pc385 to run it.
I looked at the small projects that i can do to contribute? They all seem
really hard. What is the easiest coding task (as they word it on the wiki
article )? What is a good way to get to know  rtems and rtosn general?
Thanks Mritunjay your tutorial helped so much!
Il giorno mer 26 ago 2020 alle ore 23:47 Mritunjay Sharma <
mritunjaysharma394 at gmail.com> ha scritto:
> *From:* users <users-bounces at rtems.org> on behalf of Zacchaeus Liang <
> zliang111 at gmail.com>
> *Sent:* Thursday, August 27, 2020 7:00 AM
> *To:* Jan.Sommer at dlr.de
> *Cc:* RTEMS Users RTEMS
> *Subject:* Re: BSP missing
> 'm currently getting an error that  the arch and the bsp is not found
> zakonrockets at zakonrockets-Inspiron-15-7000-Gaming:~/development/app/hello$
> ./waf configure --rtems=$HOME/development/rtems/5 --rtems-bsp=pc386
> Hi Zacchaeus, try using
> --rtems-bsp=i386/pc386 instead of
> --rtems-bsp=pc386.
>  I think it should work.
> Thanks
> Mritunjay Sharma
> Try using
> Setting top to                           :
> /home/zakonrockets/development/app/hello
> Setting out to                           :
> /home/zakonrockets/development/app/hello/build
> No valid arch/bsps found
> (complete log in /home/zakonrockets/development/app/hello/build/config.log)
> thanks zack
> Il giorno mar 25 ago 2020 alle ore 17:04 <Jan.Sommer at dlr.de> ha scritto:
>> > I followed this tutorial from a GSOC student.
>> https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
>> > This is how i've configured it.
>> > $HOME/development/rtems/rtems-5/configure --target=i386-rtems5
>> --enable-rtemsbsp=pc386 --enable-tests=samples
>> --prefix=$HOME/development/rtems/5 --enable-cxx --enable-networking
>> --enable-posix
>> Here you configure a build of the pc386 BSP.
>> > And i was able to test it with
>> > home/zakonrockets/development/rtems/5/bin/rtems-test
>> --rtems-tools=/home/zakonrockets/development/rtems/5 --rtems-bsp=pc-qemu
>> /home/zakonrockets/development/rtems/kernels-5/pcp-386/i386-rtems5/c/pc386/testsuites
>> --rtems-prefix=/home/zakonrockets/development/rtems/5
>> > I don't quite know the name of my BSP currently I think it's pc 386 but
>> it's not found. Am a correct to assume that it is?
>> Yes, it should be the pc386 BSP.
>> What do you mean by it is not found? If you search for "ticker.exe" do
>> you find the testsuites/samples directory which should contain it?
>> Best regards,
>>    Jan
>> > Il giorno mar 25 ago 2020 alle ore 16:17 <Jan.Sommer at dlr.de> ha
>> scritto:
>> > > -----Original Message-----
>> > > From: users [mailto:users-bounces at rtems.org] On Behalf Of Gedare
>> Bloom
>> > > Sent: Tuesday, August 25, 2020 9:15 PM
>> > > To: Zacchaeus Liang
>> > > Cc: RTEMS Users RTEMS
>> > > Subject: Re: BSP missing
>> > > Hi Zack,
>> > > On Tue, Aug 25, 2020 at 1:02 PM Zacchaeus Liang <zliang111 at gmail.com>
>> > > wrote:
>> > > > So I was able to build the bsp and all of the tests pass. I'm
>> currently trying
>> > > to build the hello world app.
>> > > Gaming:~/development/app/hello$ ./waf configure --
>> > > rtems=$HOME/development/rtems/5 --rtems-bsp=pc-qemu
>> > > > Setting top to                           :
>> > > > Setting out to                           :
>> > > > (complete log in
>> > > Is this from rtems-examples.git? Or something else?
>> > pc-qemu exists in a configuration for the rtems-tester, but it is only
>> a different way to execute the pc686 binaries on qemu instead via tftp on
>> actual hardware (for more see here:
>> https://git.rtems.org/rtems-tools/tree/tester/rtems/testing/bsps/pc-qemu.ini
>> > I haven't encountered it somewhere else.
>> > Best regards,
>> >    Jan
>> > > Please check out rtems-examples.git/README.waf for some assistance on
>> > > how to use the rtems_waf to build an application.
>> > > > Thanks
>> > > > Zack
>> > > > _______________________________________________
>> > > > users mailing list
>> > > > users at rtems.org
>> > > > http://lists.rtems.org/mailman/listinfo/users
>> > > users mailing list
>> > > users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200828/23fcd7ff/attachment.html>
