Help with building rtems in Ubuntu
Niteesh gsnb.gn at gmail.com
Sun Feb 9 17:00:47 UTC 2020
Do you have /bin in your PATH variable? if not you can add it using
export PATH="/bin/:$PATH"
IMHO this should fix your problem. If it doesn't and you find any other
correct solution
please let me know.
On Sun, Feb 9, 2020 at 8:41 PM Ashwin Godbole <dev.godboleashwin at gmail.com>
wrote:
> So i was able to get rtems installed and built, but that didn't come
> easily. So I have compiled my thoughts in a blog post.
> I hope this helps others too. I want to know if there is any way I can get
> this across to as many beginners as possible because running into build
> problems could discourage newcomers from trying out software.
> View the post here:
> https://devshwin.blogspot.com/2020/02/rtems.html
> I hope this message is appropriate for this mailing list. If not, i
> sincerely apologize.
> Thanks in advance for any advice.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200209/db898540/attachment.html>
