Error While building BSP | erc32 | sparc-rtems-4.11.3
Bran S
archsbran at gmail.com
Mon Jan 27 11:17:24 UTC 2020
On Monday, 27 January 2020, Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> I noted that you have a RTEMS 4.11 toolchain. But it seems that you use
> the instructions for the RTEMS master (which has a Version 5). Did you
> use a matching RTEMS 4.11 branch for your build?
I used the tar files:
https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.3/rtems-4.11.3.tar.xz
curl
https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.3/rtems-source-builder-4.11.3.tar.xz
I have now instead built it using the the git repo as mentioned in the
quick-start document. It is running fine, with some minor issues:
1) Five BSP erc32 tests fail, namely:
dl06.exe
dl09.exe
terminos09.exe
psxfenv01.exe
psxmsgq03.exe
2) On running `sparc-rtems5-gdb hello.exe` and doing `target sim`
gdb shows: Undefined target command: "sim"
Going through archives I found that others have also faced the same problem
and using `sparc-rtems5-sis` was suggested as a workaround.
I tried and it solved the problem.
Although I am not clear on why these problems occurred.
URL: <http://lists.rtems.org/pipermail/users/attachments/20200127/5ead26ec/attachment.html>
