I2C for raspberry pi 2 error
Mario Palomares
palomares.mario14 at gmail.com
Wed Mar 11 17:25:16 UTC 2020
I'am currently trying to make a program that reads and writes through the
i2c serial communication. The problem is that when i try to initialize GPIO
header through the funciton "rpi_setup_i2c_bus()" I get this error:
assertion "rtems_semaphore_obtain(gpio_bank_state[bank].lock, RTEMS_WAIT,
RTEMS_NO_TIMEOUT ) == RTEMS_SUCCESSFUL" failed: file
"../../../../../../../../rtems-git/c/src/lib/libbsp/arm/raspberrypi/../../../../../../bsps/shared/dev/gpio/gpio-support.c",
line 500, function: gpio_multi_select
That function is provided in the file "/bsp/i2c.h". If you look at that
function it just calls other two
- rpi_i2c_init(): Sets the GPIO header for I2C
- rpi_i2c_register_bus("/dev/i2c",DEFAULT_BUS_CLOCK): Sets up the
bus on the device "dev/i2c"
I have tried to exectue those two separately and i can say that it is the
first one the one that throws the error. If i don´t put that function the
second one executes correctly but later on i can not open the device file.
I have no idea how to solve it. Thanks in advance
URL: <http://lists.rtems.org/pipermail/users/attachments/20200311/6365828d/attachment.html>
