Interested in contributing to Beaglebone BSP
Christian Mauderer
oss at c-mauderer.de
Mon May 4 15:52:04 UTC 2020
Hello James,
On 04/05/2020 12:26, James Fitzsimons wrote:
> Hi Christian and Vijay,
> Firstly thank you so much for your replies they were extremely helpful
> and much appreciated.
> On Mon, 4 May 2020 at 02:50, Vijay Kumar Banerjee <vijay at rtems.org
> <mailto:vijay at rtems.org>> wrote:
> On Sun, May 3, 2020 at 8:12 PM Christian Mauderer <oss at c-mauderer.de
> <mailto:oss at c-mauderer.de>> wrote:
> Note that the repo works only most of the time. It's more of a
> test repo
> for me that just collects the necessary commands and
> repositories so I
> don't have to type everything manually.
> The dtc that I build there currently doesn't work. I removed the
> step
> from the makefile so that the host dtc is used again
> Understood. it is extremely useful for people getting started with rtems
> on the BeagleBone though! On my Ubuntu 18.04 host the system dtc was
> version 1.4.5 which also didn't support the -@ option, so I took Vijays
> advice and downloaded and built 1.6.0 which solved the problem.
It's only relevant if you want to build overlays (which I do in my
repo). That is necessary for example when you want to use HDMI. If you
don't want HDMI you can just build the base FDT without the -@ option
and load only that. That should work fine too. If it doesn't work you
found a bug.
> That's correct. The -@ or --symbols is only there in newer dtc
> versions.
> Out of interest: Where did you find that the option is
> deprecated? It is
> still there in 1.6.0.
> That must be my mistake. I was sure I read that the other night but
> can't find the website or thread I was reading now so it was probably
> either bad information or my misinterpretation - apologies for that.
No problem. I would have just tried to move to an alternative if that
option would have been deprecated.
Best regards
Christian
> > If I then run the following steps in the makefile manually,
> > bootstrap and bsp complete, but libbsd fails with the
> following error:
> > [1497/2193] Compiling freebsd/sys/netpfil/pf/pf_lb.c
> > ../../freebsd/sys/arm/freescale/imx/imx6_ccm.c:54:10:
> fatal error:
> > arm/freescale/imx/imx_ccmvar.h: No such file or directory
> > #include <arm/freescale/imx/imx_ccmvar.h>
> > compilation terminated.
> > This bug was recently fixed in the rtems-libbsd ( for both
> master and
> > 5-freebsd-12 branches), if you update to recent HEAD of the
> libbsd, then
> > this error will hopefully not be there.
> Thanks for this. I thought my rtems-libbsd repo was up to date, but I
> did a git pull --recurse-submodules and now make libbsd succeeds.
> Loading the hello world test app onto the board produces the expected
> output in a terminal session, so I think I am now in a position to make
> a start on the eQEP driver.
> Many thanks for your help!
> Regards
> James Fitzsimons
