When to register termios devices?
Wed Nov 4 14:59:56 UTC 2020
Hello Jan,
if it is a custom BSP, why don't you add it to the console driver of
this BSP?
If you add
RTEMS_SYSINIT_ITEM(
  register_additional_termios,
RTEMS_SYSINIT_DEVICE_DRIVERS,
RTEMS_SYSINIT_ORDER_LAST_BUT_5
to the module which defines bsp_start(), then your drivers are
registered. They are also registered, when the application doesn't need
them. So, doing a driver registration in the application configuration
is not that bad.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
