Need help cleaning up git repository
Gedare Bloom
gedare at rtems.org
Thu Nov 5 17:10:41 UTC 2020
On Thu, Nov 5, 2020 at 9:17 AM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Nov 5, 2020 at 9:51 AM <dufault at hda.com> wrote:
>> > On Nov 5, 2020, at 09:40 , Jan.Sommer at dlr.de wrote:
>> > Ok, I hope I understand everything correctly.
>> > Still, best to make a local copy of your repository directory.
>> I shall do that.
>> >> You can see that my master is ahead of origin/master, and my local branches
>> >> that I'd like to clean up (e.g. mvme5500-final, atsam-fixes) also include those
>> >> changes.
>> >> I think I want to do something like:
>> >> - Rename my local master branch to a branch name that is related to the
>> >> changes I put in;
>> > # Create a new branch from your local master branch under a new name
>> > $ git branch NewBranchName master
>> > # Reset the local master branch to be in line with origin/master (your changes will still be in NewBranchName)
>> > $ git checkout master
>> > $ git reset --hard origin/master
>> This sounds straight-forward.
>> >> - Drop the changes I made that on that branch in the other branches, e.g
>> >> mvme5500-final, atsam-fixes etc so that those branches are now based on
>> >> origin/master and only have the changes related to what I was working on.
>> > You might achieve that with a rebase in the respective branch, e.g. for mvme5500-final:
>> > $ git checkout mvme5500-final
>> > $ git rebase -i origin/master
>> > This should open a terminal with all commits in this branch since origin/master with the oldest commit at the top.
>> > Simply, delete the full lines of all the commits you don't want to keep in the branch, i.e. the one from your old master, save and close.
>> > If you are lucky and no conflicts appear, you end up with a branch which is based on origin/master with only the commits you want.
>> > Another option would be to create a new branch based on origin master and cherry-pick the commits you want to keep from mvme5500-final using git cherry-pick.
>> > $ git branch mvme5500-new mvme5500-final
>> > $ git checkout mvme5500-new
>> > # Cherry-pick a single commit
>> > $ git cherry-pick <commit hash>
>> > # Cherry-pick a set of continuous commits
>> > § git cherry-pick <first commit>~..<last commit> # make sure to have the "~" after the first hash
>> > That's what I could come up with so far.
>> I'll try your first suggestion "rebase in the respective branch".
>> "mvme5500-final" has too many changes to submit in one chunk. Next I'll need to figure out the best way to split those up into manageable, reviewable pieces.
> Sometimes I merge and reorder patches using "git rebase -i master" as a starting point.
> Then if it is bad enough, I do a format-patch and start another branch. Some patches I
> apply with git am. Others I apply using patch and commit pieces. This helps you regroup
> until you get coherent and discrete patches.
> This works well if you have changes scattered across files. But if you have changes
> to a single file for multiple purposes you want to submit as separate patches, I have
> stooped to editing the diff file and using patch to apply it in pieces.
You can do this more elegantly with 'e'dit option in git-rebase. Use
git reset to "uncommit" this file, then loop:
git add -p to choose which hunks to add
git commit
until you finish adding the changes
This process is documented in man git-rebase "SPLITTING COMMITS" section.
> This sounds tedious but after you do it a few times, it will become second nature.
> I try to be careful never to commit unrelated changes and then use rebase to
> combine as needed before submitting.
> As to your first problem, my procedure is to export the changes as patches, save
> the git repo with the mess, reclone, make a working branch in the new clone, and
> pick away. I'm scared of destroying work and the new clone makes me more
> conformatable that I am not screwing up something with git magic.
> --joel
>> Thanks.
>> Peter
>> Peter Dufault
>> HD Associates, Inc. Software and System Engineering
>> This email is delivered through the public internet using protocols subject to interception and tampering.
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
