Compilation error in compiling RISC-V bsps
somesh deshmukh
someshdeshmukh07 at gmail.com
Fri Nov 6 14:33:02 UTC 2020
Hi,
I am trying to compile rv64imafd BSP and I am facing the following issues.
Error log pasted below:
Making all-am in libtests
gmake[5]: Entering directory
'/home/somesh/rtos/rtems/src/kernel/rv64imafd/riscv-rtems5/c/rv64imafd/testsuites/libtests'
rtems-ld -r
/home/somesh/rtos/rtems/src/kernel/rv64imafd/riscv-rtems5/c/rv64imafd \
-C riscv-rtems5-gcc -c "-march=rv64imafd -mabi=lp64d" \
-O rap -b dl06.pre -e rtems_main -s \
-o dl06.rap dl06-o1.o dl06-o2.o -lm
error: rap::object: Section index '0' not found: dl06-o1.o
gmake[5]: *** [Makefile:8479: dl06.rap] Error 10
gmake[5]: Leaving directory
The command I used for building the BSP is pasted below:
*../rtems/configure --prefix=$HOME/rtos/rtems/5 --target=riscv-rtems5
--enable-rtemsbsp=rv64imafd --enable-tests --enable-posix
--disable-networking*
I am using latest release of RTEMS v5.1 on ubuntu v20 system.
I found the discussion related to similar issue at following link:
https://www.mail-archive.com/devel@rtems.org/msg24899.html
There is a ticket raised for the same issue:
https://devel.rtems.org/ticket/4011
What is the status of this ticket?
Regards,
Somesh
URL: <http://lists.rtems.org/pipermail/users/attachments/20201106/209c2790/attachment.html>
