Compilation error in compiling RISC-V bsps
somesh deshmukh
someshdeshmukh07 at gmail.com
Thu Nov 12 04:42:00 UTC 2020
Hi All,
Gentle reminder!!
Can you please give some update on this query?
I am looking into developing a custom bsp for risc-v board and an update on
this query will be very helpful.
Regards,
Somesh
On Fri, Nov 6, 2020 at 8:03 PM somesh deshmukh <someshdeshmukh07 at gmail.com>
wrote:
> Hi,
> I am trying to compile rv64imafd BSP and I am facing the following issues.
> Error log pasted below:
> Making all-am in libtests
> gmake[5]: Entering directory
> '/home/somesh/rtos/rtems/src/kernel/rv64imafd/riscv-rtems5/c/rv64imafd/testsuites/libtests'
> rtems-ld -r
> /home/somesh/rtos/rtems/src/kernel/rv64imafd/riscv-rtems5/c/rv64imafd \
> -C riscv-rtems5-gcc -c "-march=rv64imafd -mabi=lp64d" \
> -O rap -b dl06.pre -e rtems_main -s \
> -o dl06.rap dl06-o1.o dl06-o2.o -lm
> error: rap::object: Section index '0' not found: dl06-o1.o
> gmake[5]: *** [Makefile:8479: dl06.rap] Error 10
> gmake[5]: Leaving directory
> The command I used for building the BSP is pasted below:
> *../rtems/configure --prefix=$HOME/rtos/rtems/5 --target=riscv-rtems5
> --enable-rtemsbsp=rv64imafd --enable-tests --enable-posix
> --disable-networking*
> I am using latest release of RTEMS v5.1 on ubuntu v20 system.
> I found the discussion related to similar issue at following link:
> https://www.mail-archive.com/devel@rtems.org/msg24899.html
> There is a ticket raised for the same issue:
> https://devel.rtems.org/ticket/4011
> What is the status of this ticket?
> Regards,
> Somesh
URL: <http://lists.rtems.org/pipermail/users/attachments/20201112/0217250a/attachment.html>
