libbsd select timeout issue(critial!!)
Sebastian Huber
Wed Nov 11 06:42:36 UTC 2020
On 11/11/2020 03:50, RUI Zhengxin wrote:
> This issue is very critial, it can make the select abnormally return
> timeout after long run time.
> If the timeout is set to 5ms, when the system run after 70000s(19.4h),
> the select function will wait 10ms timeout, which is two times of
> setting value.
> This issue is created by calculating timeout watchdog expire tick
> using the absolute time since libbsd5 version.
Yes, the calculation of the absolute timeout is broken. Could you please
add a bug report:
https://docs.rtems.org/branches/master/user/support/bugs.html
It would be nice if you could create a patch which fixes the bug.
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
