libbsd select timeout issue(critial!!)
RUI Zhengxin
ruizx at 126.com
Tue Nov 17 02:04:48 UTC 2020
Hi Sebastian,
The bug report is added, a patch which using relative timeout is attached.
It has no time drift during 1 week testing.
https://devel.rtems.org/ticket/4179
在 2020-11-11 14:42:36,"Sebastian Huber" <sebastian.huber at embedded-brains.de> 写道:
>On 11/11/2020 03:50, RUI Zhengxin wrote:
>> This issue is very critial, it can make the select abnormally return
>> timeout after long run time.
>> If the timeout is set to 5ms, when the system run after 70000s(19.4h),
>> the select function will wait 10ms timeout, which is two times of
>> setting value.
>> This issue is created by calculating timeout watchdog expire tick
>> using the absolute time since libbsd5 version.
>Yes, the calculation of the absolute timeout is broken. Could you please
>add a bug report:
>https://docs.rtems.org/branches/master/user/support/bugs.html
>It would be nice if you could create a patch which fixes the bug.
>embedded brains GmbH
>Sebastian HUBER
>Dornierstr. 4
>82178 Puchheim
>Germany
>email: sebastian.huber at embedded-brains.de
>Phone: +49-89-18 94 741 - 16
>Fax: +49-89-18 94 741 - 08
>PGP: Public key available on request.
>Registergericht: Amtsgericht München
>Registernummer: HRB 157899
>Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/users/attachments/20201117/e0f87b84/attachment-0001.html>
