Compilation error in compiling RISC-V bsps
Chris Johns
chrisj at rtems.org
Thu Nov 12 22:15:58 UTC 2020
On 13/11/20 3:00 am, Joel Sherrill wrote:
> The tests that start with dl are dynamic loader tests. They require architecture
> specific support which sometimes breaks. That's why there is a ticket until it
> gets addressed by someone. Things get fixed as either volunteers step up or
> someone gets funded to fix them.
> You should be to do "make -k" to ignore this error and continue or, more
> cleanly, add a ".tcfg" file to the BSP's config directory to specify that this
> test should be excluded. bsps/riscv/riscv/config/rv64imafd-testsuite.tcfg which
> should need only one line:
> expected-fail: dl06
> There are lots of other .tcfg files to look at for examples.
The expected fail state is a runtime state so the test still needs to build.
