problem in building BSP erc32
Gedare Bloom
gedare at rtems.org
Mon Feb 1 19:44:51 UTC 2021
Ayushman,
Have a look at
https://docs.rtems.org/branches/master/user/start/preparation.html#selecting-a-version-of-rtems
If you think there are other places that might be helpful to point back to
this section, it would be great to know. It is hard for us to emulate how
new users navigate these things. We know from experience that it tends to
be not linear :)
Gedare
On Mon, Feb 1, 2021 at 12:37 PM Ayushman Mishra <ayushvidushi01 at gmail.com>
wrote:
> Thank you for your response.
> On Tue, Feb 2, 2021, 1:03 AM Gedare Bloom <gedare at rtems.org> wrote:
>> Hi Ayushman,
>> The 'master' branches default to the next version number for release. So
>> you would want to be using version 6, or else switch to version 5
>> explicitly. For new development and getting involved with RTEMS we
>> recommend using the development versions.
>> I guess we need to fix that version number, we have this problem of
>> version numbers growing stale in the documentation.
>> Gedare
>> On Mon, Feb 1, 2021 at 12:28 PM Ayushman Mishra <ayushvidushi01 at gmail.com>
>> wrote:
>>> Hello everyone , I am Ayushman (chetak123) Btech 2nd year new to the
>>> RTEMS organization . I have installed rtems5-sparc and trying to
>>> build BSP erc32
>>> (https://docs.rtems.org/branches/master/user/start/bsp-build.html) but
>>> I am getting BUILD FAIL while trying to do it using RSB and when doing
>>> it manually there was no waf or wscript file present in branch 5 of
>>> rtems git repository (in which I am currently working) , so downloaded
>>> waf executable and copied wscript along with yaml and spec/build
>>> directory from master branch into my working branch but now when I run
>>> ./waf configure --prefix=$HOME/quick-start/rtems/5 it starts looking
>>> for rtems6 instead of 5 (Could not find the program
>>> ['sparc-rtems6-gcc'] ) and I am really stuck here.
>>> I would be very thankful if somebody can please help me.
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20210201/a55984a2/attachment.html>
