problem in building BSP erc32
Ayushman Mishra
ayushvidushi01 at gmail.com
Mon Feb 1 19:37:25 UTC 2021
Thank you for your response.
On Tue, Feb 2, 2021, 1:03 AM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Ayushman,
> The 'master' branches default to the next version number for release. So
> you would want to be using version 6, or else switch to version 5
> explicitly. For new development and getting involved with RTEMS we
> recommend using the development versions.
> I guess we need to fix that version number, we have this problem of
> version numbers growing stale in the documentation.
> Gedare
> On Mon, Feb 1, 2021 at 12:28 PM Ayushman Mishra <ayushvidushi01 at gmail.com>
> wrote:
>> Hello everyone , I am Ayushman (chetak123) Btech 2nd year new to the
>> RTEMS organization . I have installed rtems5-sparc and trying to
>> build BSP erc32
>> (https://docs.rtems.org/branches/master/user/start/bsp-build.html) but
>> I am getting BUILD FAIL while trying to do it using RSB and when doing
>> it manually there was no waf or wscript file present in branch 5 of
>> rtems git repository (in which I am currently working) , so downloaded
>> waf executable and copied wscript along with yaml and spec/build
>> directory from master branch into my working branch but now when I run
>> ./waf configure --prefix=$HOME/quick-start/rtems/5 it starts looking
>> for rtems6 instead of 5 (Could not find the program
>> ['sparc-rtems6-gcc'] ) and I am really stuck here.
>> I would be very thankful if somebody can please help me.
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20210202/40afbd9d/attachment.html>
