RTEMS5 checksum failure file: sources/jpegsrc.v9a
Chris Johns
chrisj at rtems.org
Tue Feb 2 00:34:53 UTC 2021
On 2/2/21 4:36 am, Gedare Bloom wrote:
> Indeed. It seems the sha512 has changed. The file doesn't appear to be different
> on the http server. I found a copy
> at https://download.videolan.org/contrib/jpeg/
> <https://download.videolan.org/contrib/jpeg/> that has a matching sha512sum as
> we expect in the RSB.
RSB matching version is:
https://ftp.rtems.org/pub/rtems/releases/5/5.1/sources/jpegsrc.v9a.tar.gz
Releases copy in the sources to protect against this. Please consider a ticket
and patch for the RSB for the 5 branch as OK given ...
> I compared those two tar files, and found this:
> --rw-r--r-- 1 gedare gedare 4807 May 2 2010 makejvcx.v10
> --rw-r--r-- 1 gedare gedare 3595 May 2 2010 makecvcx.v10
> --rw-r--r-- 1 gedare gedare 3595 May 2 2010 makedvcx.v10
> --rw-r--r-- 1 gedare gedare 2876 May 2 2010 makervcx.v10
> --rw-r--r-- 1 gedare gedare 3535 May 2 2010 maketvcx.v10
> --rw-r--r-- 1 gedare gedare 2876 May 2 2010 makewvcx.v10
> --rw-r--r-- 1 gedare gedare 2288 May 2 2010 makecfil.v10
> --rw-r--r-- 1 gedare gedare 2288 May 2 2010 makedfil.v10
> --rw-r--r-- 1 gedare gedare 1142 May 2 2010 makerfil.v10
> --rw-r--r-- 1 gedare gedare 2123 May 2 2010 maketfil.v10
> --rw-r--r-- 1 gedare gedare 1142 May 2 2010 makewfil.v10
> --rw-r--r-- 1 gedare gedare 1859 May 1 2010 makeasln.v10
> --rw-r--r-- 1 gedare gedare 679 May 1 2010 makejsln.v10
> --rw-r--r-- 1 gedare gedare 5789 May 1 2010 makejfil.v10
> +-rw-r--r-- 1 gedare gedare 4804 May 2 2010 makejvcx.v10
> +-rw-r--r-- 1 gedare gedare 3592 May 2 2010 makecvcx.v10
> +-rw-r--r-- 1 gedare gedare 3592 May 2 2010 makedvcx.v10
> +-rw-r--r-- 1 gedare gedare 2873 May 2 2010 makervcx.v10
> +-rw-r--r-- 1 gedare gedare 3532 May 2 2010 maketvcx.v10
> +-rw-r--r-- 1 gedare gedare 2873 May 2 2010 makewvcx.v10
> +-rw-r--r-- 1 gedare gedare 2285 May 2 2010 makecfil.v10
> +-rw-r--r-- 1 gedare gedare 2285 May 2 2010 makedfil.v10
> +-rw-r--r-- 1 gedare gedare 1139 May 2 2010 makerfil.v10
> +-rw-r--r-- 1 gedare gedare 2120 May 2 2010 maketfil.v10
> +-rw-r--r-- 1 gedare gedare 1139 May 2 2010 makewfil.v10
> +-rw-r--r-- 1 gedare gedare 1856 May 1 2010 makeasln.v10
> +-rw-r--r-- 1 gedare gedare 676 May 1 2010 makejsln.v10
> +-rw-r--r-- 1 gedare gedare 5786 May 1 2010 makejfil.v10
> It appears that someone has removed some unicode characters or similar ( <8b>¯¨
> ) from the file header line
> +<?xml version="1.0" encoding="utf-8"?>
> of all these .v10 files in the ijg.org <http://ijg.org> download, without
> somehow modifying the file metadata.
Thanks
